4refr0nt wrote:TheQuestor wrote:I just flashed a ESP07 with micropython
micropythons commands and filesystem not supported in latest ESPlorer version, but you can use ESPlorer for sending manually entered micropython commands
That explains a lot
Explore... Chat... Share...
Bertram Kaufmann wrote:If you use this Tool on OSX and connect a new ESP8266 so the Programm is frozen,
after a new Start from OSX you can use it again
