on Chriscook8 post viewtopic.php?f=29&t=2520
I modified to use ESP8266WebServer.h for handle RestAPI easily
here gist update https://gist.github.com/dogrocker/f998dde4dbac923c47c1
#include <ESP8266mDNS.h>
#include <ESP8266WebServer.h>
#include <EEPROM.h>
MDNSResponder mdns;
ESP8266WebServer server(80);
const char* ssid = "BUBBLES";
const char* passphrase = "BUBBLES";
String st;
String content;
EEPROM.begin(512);
delay(10);
Serial.println("Startup");
// read eeprom for ssid and pass
Serial.println("Reading EEPROM ssid");
String esid;
for (int i = 0; i < 32; ++i)
esid += char(EEPROM.read(i));
Serial.print("SSID: ");
Serial.println(esid);
Serial.println("Reading EEPROM pass");
String epass = "";
for (int i = 32; i < 96; ++i)
epass += char(EEPROM.read(i));
Serial.print("PASS: ");
Serial.println(epass);
if ( esid.length() > 1 ) {
// test esid
WiFi.begin(esid.c_str(), epass.c_str());
if (testWifi()) {
launchWeb(0);
return;
setupAP();
bool testWifi(void) {
int c = 0;
Serial.println("Waiting for Wifi to connect");
while ( c < 20 ) {
if (WiFi.status() == WL_CONNECTED) { return true; }
Serial.print(WiFi.status());
c++;
Serial.println("");
Serial.println("Connect timed out, opening AP");
return false;
void launchWeb(int webtype) {
Serial.println("");
Serial.print("Local IP: ");
Serial.print("SoftAP IP: ");
Serial.println(WiFi.softAPIP());
if (!mdns.begin("esp8266", WiFi.localIP())) {
Serial.println("Error setting up MDNS responder!");
while(1) {
delay(1000);
Serial.println("mDNS responder started");
createWebServer(webtype);
// Start the server
server.begin();
void setupAP(void) {
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
int n = WiFi.scanNetworks();
Serial.println("scan done");
if (n == 0)
Serial.println("no networks found");
Serial.print(n);
Serial.println(" networks found");
for (int i = 0; i < n; ++i)
// Print SSID and RSSI for each network found
Serial.print(i + 1);
Serial.print(": ");
Serial.print(WiFi.SSID(i));
Serial.print(" (");
Serial.print(WiFi.RSSI(i));
Serial.print(")");
Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE)?" ":"*");
delay(10);
Serial.println("");
st = "<ol>";
st += "<li>";
st += WiFi.SSID(i);
st += " (";
st += WiFi.RSSI(i);
st += ")";
st += (WiFi.encryptionType(i) == ENC_TYPE_NONE)?" ":"*";
st += "</li>";
st += "</ol>";
delay(100);
WiFi.softAP(ssid);
Serial.println("softap");
launchWeb(1);
Serial.println("over");
void createWebServer(int webtype)
// Check for any mDNS queries and send responses
mdns.update();
if ( webtype == 1 ) {
server.on("/", []() {
IPAddress ip = WiFi.softAPIP();
String ipStr = String(ip[0]) + '.' + String(ip[1]) + '.' + String(ip[2]) + '.' + String(ip[3]);
content = "<!DOCTYPE HTML>\r\n<html>Hello from ESP8266 at ";
content += ipStr;
content += "<p>";
content += st;
content += "</p><form method='get' action='setting'><label>SSID: </label><input name='ssid' length=32><input name='pass' length=64><input type='submit'></form>";
content += "</html>";
server.send(200, "text/html", content);
server.on("/setting", []() {
String qsid = server.arg("ssid");
String qpass = server.arg("pass");
if (qsid.length() > 0 && qpass.length() > 0) {
Serial.println("clearing eeprom");
for (int i = 0; i < 96; ++i) { EEPROM.write(i, 0); }
Serial.println(qsid);
Serial.println("");
Serial.println(qpass);
Serial.println("");
Serial.println("writing eeprom ssid:");
for (int i = 0; i < qsid.length(); ++i)
EEPROM.write(i, qsid[i]);
Serial.print("Wrote: ");
Serial.println(qsid[i]);
Serial.println("writing eeprom pass:");
for (int i = 0; i < qpass.length(); ++i)
EEPROM.write(32+i, qpass[i]);
Serial.println(qpass[i]);
EEPROM.commit();
content = "<!DOCTYPE HTML>\r\n<html>";
content += "<p>saved to eeprom... reset to boot into new wifi</p></html>";
} else {
content = "Error";
Serial.println("Sending 404");
} else {
server.send(200, "text/plain", "this works as well");
server.send(200, "text/plain", "setting.");
server.on("/cleareeprom", []() {
content += "<p>Clearing the EEPROM</p></html>";
EEPROM.commit();
server.handleClient();
