By kanin03
#15504 The idea by esp-arduino-apboot
on Chriscook8 post viewtopic.php?f=29&t=2520
I modified to use ESP8266WebServer.h for handle RestAPI easily
here gist update https://gist.github.com/dogrocker/f998dde4dbac923c47c1
#include <ESP8266mDNS.h>
#include <ESP8266WebServer.h>
#include <EEPROM.h>
MDNSResponder mdns;
ESP8266WebServer server(80);
const char* ssid = "BUBBLES";
const char* passphrase = "BUBBLES";
String st;
String content;
  EEPROM.begin(512);
  delay(10);
  Serial.println("Startup");
  // read eeprom for ssid and pass
  Serial.println("Reading EEPROM ssid");
  String esid;
  for (int i = 0; i < 32; ++i)
      esid += char(EEPROM.read(i));
  Serial.print("SSID: ");
  Serial.println(esid);
  Serial.println("Reading EEPROM pass");
  String epass = "";
  for (int i = 32; i < 96; ++i)
      epass += char(EEPROM.read(i));
  Serial.print("PASS: ");
  Serial.println(epass);
  if ( esid.length() > 1 ) {
      // test esid
      WiFi.begin(esid.c_str(), epass.c_str());
      if (testWifi()) {
          launchWeb(0);
          return;
  setupAP();
bool testWifi(void) {
  int c = 0;
  Serial.println("Waiting for Wifi to connect");
  while ( c < 20 ) {
    if (WiFi.status() == WL_CONNECTED) { return true; }
    Serial.print(WiFi.status());
    c++;
  Serial.println("");
  Serial.println("Connect timed out, opening AP");
  return false;
void launchWeb(int webtype) {
  Serial.println("");
  Serial.print("Local IP: ");
  Serial.print("SoftAP IP: ");
  Serial.println(WiFi.softAPIP());
  if (!mdns.begin("esp8266", WiFi.localIP())) {
    Serial.println("Error setting up MDNS responder!");
    while(1) {
      delay(1000);
  Serial.println("mDNS responder started");
  createWebServer(webtype);
  // Start the server
  server.begin();
void setupAP(void) {
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  int n = WiFi.scanNetworks();
  Serial.println("scan done");
  if (n == 0)
    Serial.println("no networks found");
  else
    Serial.print(n);
    Serial.println(" networks found");
    for (int i = 0; i < n; ++i)
      // Print SSID and RSSI for each network found
      Serial.print(i + 1);
      Serial.print(": ");
      Serial.print(WiFi.SSID(i));
      Serial.print(" (");
      Serial.print(WiFi.RSSI(i));
      Serial.print(")");
      Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE)?" ":"*");
      delay(10);
  Serial.println("");
  st = "<ol>";
      st += "<li>";
      st += WiFi.SSID(i);
      st += " (";
      st += WiFi.RSSI(i);
      st += ")";
      st += (WiFi.encryptionType(i) == ENC_TYPE_NONE)?" ":"*";
      st += "</li>";
  st += "</ol>";
  delay(100);
  WiFi.softAP(ssid);
  Serial.println("softap");
  launchWeb(1);
  Serial.println("over");
void createWebServer(int webtype)
  // Check for any mDNS queries and send responses
  mdns.update();
  if ( webtype == 1 ) {
    server.on("/", []() {
        IPAddress ip = WiFi.softAPIP();
        String ipStr = String(ip[0]) + '.' + String(ip[1]) + '.' + String(ip[2]) + '.' + String(ip[3]);
        content = "<!DOCTYPE HTML>\r\n<html>Hello from ESP8266 at ";
        content += ipStr;
        content += "<p>";
        content += st;
        content += "</p><form method='get' action='setting'><label>SSID: </label><input name='ssid' length=32><input name='pass' length=64><input type='submit'></form>";
        content += "</html>";
        server.send(200, "text/html", content);
    server.on("/setting", []() {
        String qsid = server.arg("ssid");
        String qpass = server.arg("pass");
        if (qsid.length() > 0 && qpass.length() > 0) {
          Serial.println("clearing eeprom");
          for (int i = 0; i < 96; ++i) { EEPROM.write(i, 0); }
          Serial.println(qsid);
          Serial.println("");
          Serial.println(qpass);
          Serial.println("");
          Serial.println("writing eeprom ssid:");
          for (int i = 0; i < qsid.length(); ++i)
              EEPROM.write(i, qsid[i]);
              Serial.print("Wrote: ");
              Serial.println(qsid[i]);
          Serial.println("writing eeprom pass:");
          for (int i = 0; i < qpass.length(); ++i)
              EEPROM.write(32+i, qpass[i]);
              Serial.println(qpass[i]);
          EEPROM.commit();
          content = "<!DOCTYPE HTML>\r\n<html>";
          content += "<p>saved to eeprom... reset to boot into new wifi</p></html>";
        } else {
          content = "Error";
          Serial.println("Sending 404");
  } else {
      server.send(200, "text/plain", "this works as well");
      server.send(200, "text/plain", "setting.");
    server.on("/cleareeprom", []() {
      content += "<p>Clearing the EEPROM</p></html>";
      EEPROM.commit();
  server.handleClient();
By martinayotte
#38793 WiFiServer is plain TCP Socket server, you can use it for creating a Telnet Server for example.
ESP8266WebServer is using WiFiServer internally to received HTTP request, but it does all the arguments parsing and use handlers to dispatch the call according to URL paths, etc.
By acpilot
#50624 Thank you for posting this!
I'm running into a problem though. Using your example, I cannot actually get a page to appear at the IP (192.168.4.1 in this case). What could prevent the esp from hosting a html form using this code?
Again, thank you for the example.
