By russm
#48814 I got it to work. No idea what I was doing wrong earlier. I guess that's what happens when you stay up too late. V3.0 Alpha 5 works great on this board, serial port working at 9600baud
By russm
#48930 One button is for flash, the other is just a second button, forget which IO it is attached to. The two relays are separate, they bring in the AC from the input and turn on/off sockets/lights, whatever attached. There is also a place for a DHT22. Comes with case. Here is the board spec: http://www.electrodragon.com/w/ESP_Relay_Board#Pin_Mapping_and_Wiring
Forgot to mention, I was able to get the esp8266basic firmware flasher to work as well as the NodeMCU firmware flasher. You must have the flash button pressed while powering up the board.
