I tried with ESP-01, ESP-01S and WeMos D1 mini. Downloading seems OK and there are no apparent errors but none of the devices broadcast an SSID on rebooting.
If you checked that, try to see what comes out of the serial port (run it at default 9600 bps), maybe it gives a clue.
The WeMos D1 mini LED is flickering constantly and, using Putty @9600, outputs a steady stream that's indecipherable.
The programming adapter for the ESP-01 & ESP-01S does not pull-up anything other than CH_PD which may account for them appearing deaf/mute to Putty.
In any event, I've decided to use USR IOT devices which are preprogrammed and which have USR IOT virtual serial port software.
https://www.usriot.com/products/uart-wifi-modules/
