Is it ok to use micro batteries like those as power supply? http://www.topnews.in/files/micro-batteries.jpg
Probably substantially less than an hour on a button cell
Explore... Chat... Share...
RogerClark wrote:Is it ok to use micro batteries like those as power supply? http://www.topnews.in/files/micro-batteries.jpg
RogerClark wrote:You can put the device to sleep when not in use, but you will need to wake it up when a switch is pressed, using an interrupt.
Someone else will need to tell you if the device can do this, especially with multiple buttons.
