Server starting at port:9999
OK
Server Tomeout :600 sec
OK
I guess that should be "Timeout".
Explore... Chat... Share...
OK
SEND OK
<< AP GOOD ...>
+IPD,251,7:NO IP
OK
SEND OK
CIFSTATUS
ERROR
<< AP GOOD ...
ERROR
+CWJAP:1
FAIL
Scan starting...Data Scan Completed
Short Neighbors(1):"MESH-13404",-23,1a:fe:34:9f:4e:ef
Short Neighbors(2):"MESH-91551",-25,1a:fe:34:9a:59:bf
Short Neighbors(3):"MESH-80435",-40,1a:fe:34:9d:fb:00
Connecting...>>>>>>>>>>>> +CWJAP:1
FAIL
Short N
chandan2002x wrote:..... Use CIFSR to check links. Use CIFSTATUS to check link-id. Its 251!!!
connect ur computer with any AP. i
scargill wrote:Ok so I'm starting to get FAIL a lot now...Code: Select allERROR
+CWJAP:1
FAIL
FAIL
Short N
