Chat freely about anything...
By scargill
#5639 Erm.. . CIFSTATUS - use of this quickly results in failure...
I managed to get a response out of the first monitored unit... once.. then...
Code: Select allOK
SEND OK
 << AP GOOD ...>
+IPD,251,7:NO IP
OK
SEND OK
CIFSTATUS
ERROR
 << AP GOOD ...
Ok so I'm starting to get FAIL a lot now...
Code: Select allERROR
+CWJAP:1
FAIL
  Scan starting...Data Scan Completed
Short Neighbors(1):"MESH-13404",-23,1a:fe:34:9f:4e:ef
Short Neighbors(2):"MESH-91551",-25,1a:fe:34:9a:59:bf
Short Neighbors(3):"MESH-80435",-40,1a:fe:34:9d:fb:00
 Connecting...>>>>>>>>>>>> +CWJAP:1
FAIL
Short N
These units incidentally are all in one room.
chandan2002x wrote:..... Use CIFSR to check links. Use CIFSTATUS to check link-id. Its 251!!!
connect ur computer with any AP. i
By alonewolfx2
#5640
scargill wrote:Ok so I'm starting to get FAIL a lot now...
+CWJAP:1
FAIL
FAIL
Short N
I have the same result
By chandan2002x
#5700 It is difficult to re-create the problem and debug it, however, I have modified couple of parts.
The problem is happening with "Time to connect" with AP. I have increased the time with periodic checking. Also, channel shifted to 1 from 11.
Please try the new binary.
Try at 115200.
As I mentioned earlier, "Only self-joining and self-healing has been implemented". The data-communication happening (between clients and server is the part of Link info sharing will be used in routing table]
A generic protection may give better result, "if an AP cant be joined after N tries, ignore it and move to next best one". However, that part is coded but not enabled because of debugging. If the current release creates the problem, that may be enabled.
Thanks.
(136.77 KiB) Downloaded 276 times
