By timofteandrei
#7572
MikeBolton wrote:
timofteandrei wrote:I searched all the forum but I haven't found any detail about how to flash new firmware on an ESP-01 with IoT firmware inside...
If you are using a Windows PC, I can give you all the details of how to do this. I agree there is little useful info. and it is not a simple or straightforward process. It doesn't seem to matter what the original firmware is. I do think there should be a simple 'tool' for doing this as it is surely the most common thing users will want to do.
Snag is, while I successfully flashed the 'new' firmware, it doesn't work !
Mike B
I'm using Windows 7 x64 Ultimate... I've tried everything believe me...I mean everything is available for the common internet user...Somebody should make a tutorial or something to avoid this type of awkward situations...You can post your solution right here because I know I'm not the only one with this problem! Thanks for reply!
By MeNoGeek
#7643 Hey Mike,
MikeBolton wrote:Python files [...] require you to use the command line interpreter or a DOS window. This is really ‘stone age’
Then why don't you use nodemcu-flasher?
https://github.com/nodemcu/nodemcu-flasher
MikeBolton wrote:You should get a set of massages
Aaaah, okay... ;)
By gwizz
#7645 I like the idea of getting a set of massages too! :)
Perhaps I should try issuing a
Code: Select allAT+HAPPY_END
and wait for something to come forth? :D
Seriously, anyone who sold you on the idea that working with ESP8266 is as easy as arduino should hang their head. It is a significant step up in difficulty, but it is 1/10 of the price and about 10x the functionality. If you are struggling with using the command line or installing stuff from github then you should probably expect to have a steep learning experience!!
But it is good that you documented your experience - it will probably help others - so thank you for that - this is why we are all here after all, to learn and to share our learning. I have attached a copy of your document in rtf format so that it is more accessible for people without Word installed.
(24.36 KiB) Downloaded 309 times
