MikeBolton wrote:timofteandrei wrote:I searched all the forum but I haven't found any detail about how to flash new firmware on an ESP-01 with IoT firmware inside...
If you are using a Windows PC, I can give you all the details of how to do this. I agree there is little useful info. and it is not a simple or straightforward process. It doesn't seem to matter what the original firmware is. I do think there should be a simple 'tool' for doing this as it is surely the most common thing users will want to do.
Snag is, while I successfully flashed the 'new' firmware, it doesn't work !
Mike B
I'm using Windows 7 x64 Ultimate... I've tried everything believe me...I mean everything is available for the common internet user...Somebody should make a tutorial or something to avoid this type of awkward situations...You can post your solution right here because I know I'm not the only one with this problem! Thanks for reply!
