By ulko
#7450 Hi cherts,
After endless trials with partly success (only webpages.espfs not OK) I'm now using version 1.0.5. with a modified version example 'esphttpd'. All compiling, linking and flash runs without any errror.
webpages.espfs also is built correctly and flashed.
In older versions I got connection via wifi to my router.
The problem now is that I don't get connection. Only the following messages:
Httpd init, conn=0x3ffeac84
Ready
mode : sta(18:fe:34:9d:eb:48) + softAP(1a:fe:34:9d:eb:48)
add if0
dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
add if1
bcn 100
scandone
no MYAP found, reconnect after 1s
reconnect
scandone
reconnect
Other examples (Hello World, dht22) work correctly.
No connection with 192.168.4.1/wifi
Do you have any idea?? May be the wifi part is defect?? What is MYAP??
Kind regards
ulko
By boseji
#7451 Hello,
Thanks a lot for your support.
I have tried to put together a Portable package of all the things that would be needed to work with ESP8266 board (ESP-01 Module in my case).
This is based on the Orignial SDK posted plus the contributions from various other people taken together.
Only a single download is enough to get the things working.
The details of my packaging are given in the Github Repo - ESP8266-uof-windows-sdk-portable.
This package is done for 64bit Windows systems only.
Direct link to the Package - ESP8266-UofWin-SDK-portable-v01.zip.
Code: Select allFile Size: 635.55 MB
MD5-SUM = a46044025137ecbfc94bce0e0c57a6e1
Kindly let me know feedback, comments or issues on this Portable package.
Warm Regards,
Boseji
By CHERTS
#7488
ulko wrote:Hi cherts,
Ready
add if0
add if1
bcn 100
scandone
reconnect
scandone
reconnect
Kind regards
ulko
Wifi config is saved in file user_config.h
By ulko
#7496
Ready
add if0
add if1
bcn 100
scandone
reconnect
scandone
reconnect
Kind regards
ulko
In existing user_config.h there is my ssid + PW but still says: 'no MYAP found'??
