After endless trials with partly success (only webpages.espfs not OK) I'm now using version 1.0.5. with a modified version example 'esphttpd'. All compiling, linking and flash runs without any errror.
webpages.espfs also is built correctly and flashed.
In older versions I got connection via wifi to my router.
The problem now is that I don't get connection. Only the following messages:
Httpd init, conn=0x3ffeac84
Ready
mode : sta(18:fe:34:9d:eb:48) + softAP(1a:fe:34:9d:eb:48)
add if0
dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
add if1
bcn 100
scandone
no MYAP found, reconnect after 1s
reconnect
scandone
reconnect
Other examples (Hello World, dht22) work correctly.
No connection with 192.168.4.1/wifi
Do you have any idea?? May be the wifi part is defect?? What is MYAP??
Kind regards
ulko
