I'm developing a IoT device, that uses the MQTT( from tuan ) + httpd codes, i mix the two codes in one to configure the device and after connect to a broker, but in user_init() function, when change the SSID of the deivce in SOFTAP mode, the DHCP just stop to work and i cannot to connect from other device in the ESP8266 unless i use the system_restore, anyone had this kind of problem?
void user_init(void)
stdoutInit();
ioInit();
//system_restore();
/****** Print Some inf. about ESP ******/
os_printf("\n\n");
os_printf("\nPrinting AP Settings:\n");
struct softap_config cfgESP;
while(!wifi_softap_get_config(&cfgESP));
os_printf("\nSSID:%s",cfgESP.ssid);
os_printf("\nPASSWORD:%s",cfgESP.password);
os_printf("\nCHANNEL:%d",cfgESP.channel);
os_printf("\nAuthentification:%d",cfgESP.authmode);
os_printf("\nSSID Hidden:%d",cfgESP.ssid_hidden);
os_printf("\nMax Connections:%d",cfgESP.max_connection);
os_printf("\n\n");
/****** Change SSID ******/
memset(cfgESP.ssid, 0, 32);
strcpy(cfgESP.ssid, WIFI_APSSID);
wifi_softap_set_config(&cfgESP);
/****** Init WS ******/
httpdInit(builtInUrls, 80);
os_printf("\nWebServer=Ready\n");
/****** MQTT polling to connect ******/
os_timer_disarm(&mqtt_timer);
os_timer_setfn(&mqtt_timer, (os_timer_func_t *)CheckForMQTT_cb, (void *)0);
os_timer_arm(&mqtt_timer, 500, 1);
os_printf("\nMQTT timer=Started\n");
