By datasung
#11696 The breadboard is from a dutch/german company called Conrad.
I own it for some years and don't have any links for buying it.
I do believe Conrad has international webshops.
All the other stuff is from aliexpress.com.
I buy there a lot, they often have complete sulotions that cost less then the individual parts.
I think you mean the CCTV jack.
If that's the case the link is http://www.aliexpress.com/item/2014-New ... 40524.html i payed 2,24 euro for 10 pcs.
The only downside to buying there is delivery time.
Gr, Data Sung
By Robus
#11735 I still have the same problem.
Schematic:
I have tried:
    Using two separate power sources (9V and 5V from an arduino), so that the relay won't cause a voltage drop on 3.3v
    Separating the ESP8266 and the relay - about 1m apart
    Trying with regular LEDs - works fine
    Adding some more capacitors - no significant difference
Whenever I switch the relay, the ESP hangs and stays with the red and blue LED on untill I reset it.
What's wrong? How can I fix this?
