- Mon Mar 23, 2015 9:15 am
#12481
New version releasedChangeLog for version 0.2.0-rc1- add new cool ESP FileManager (screenshoots at bottom in this post) Commands in popup menu: Run, Compile(New!), View(old Cat), Edit(New!), Download(New!), Rename(New!), Remove (available commands depended file extension)
- add "Upload file to ESP from disk" function (include binaries files) in left bottom panel
- add "Download file from ESP to disk" function (include binaries files) in file manager
- ESP files list ABC-autosorted
- add new button FileSystemInfo (new command file.fsinfo() since firmware 20150311 and later)
- add firmware autodetection after serial port open
- add check communication with MCU after serial port open or "change speed on the fly"
- change default window size to 1024x768 and new UI conception
- change: in all buttons/command "Run" against "Do", "View" against "Cat"
- expanded field for serial port name
- add "CustomSerialPort" on "Settings" tab (if enable this, PortScan never execute)
- add DTR and RTS buttons with LED
- add CTS LED
- add new "Links" menu
- add NodeMCU specific right panel (Heap button, Chip Info button, Chip ID button, Flash ID button)
- add toolbar Show/Hide command in "View" menu
- inc size of toolbar buttons
- add Snippets panel Show/Hide command in "View" menu
- add FileManager panel Show/Hide command in "View" menu
- add Right extra buttons panel Show/Hide command in "View" menu
- add "Use external editor" option on "Settings" tab. All files ReadOnly
- add "EOL" option - EOL visible in terminal window
- add new mode for snippets: Condensed executing (please, do not use this mode if you use commands without left operand: "=node.heap()", but "x=node.heap" work ok)
- fix AutoComplete (Ctrl+Space) bug for commands contains "."
- fix "AutoSave/AutoRestore setting enable/disable log window" bug
- fix bug: exit app without save files
- disable setting "AutoRun file after Save to ESP" (for do this - you can use new button "Save & Run" in 2.0.0-final version)
- all settings autosave when changed and autorestored after app launch
- window size autosave on close and autorestored after app launch
- editor: tab size changed from 5 to 4
- library rsyntaxtextarea updated to version 2.5.6
- some code refactoring
- improve stability
- now semver.org versioning conception (MAJOR.MINOR.PATCH)
- tested on NodeMCU 0.9.5_20150318
SpeedTestTEST:File downloadBaud rate:921600 Size:10k Time elapsed: 2080 ms
Baud rate:921600 Size:20k Time elapsed: 2811 ms
Baud rate:115200 Size:10k Time elapsed: 2841 ms
Baud rate:115200 Size:20k Time elapsed: 4261 ms
Baud rate:9600 Size:10k Time elapsed: 14 sec
Baud rate:9600 Size:20k Time elapsed: 25 sec
TEST:File uploadBaud rate:921600 Size:10k Time elapsed: 4565 ms
Baud rate:921600 Size:20k Time elapsed: 8591 ms
Baud rate:115200 Size:10k Time elapsed: 4550 ms
Baud rate:115200 Size:20k Time elapsed: 9158 ms
Baud rate:9600 Size:10k Time elapsed: 15 sec
Baud rate:9600 Size:20k Time elapsed: 29 sec
TODO for v0.2.0- add AT commands v0.22 support
- add SaveAs... command in "File" menu
- add popup menu with "Copy" and "Paste" functions in command field
- add Left extra buttons panel Show/Hide command in "View" menu with buttons:
* add "Save & Run" button
* add "Save & Compile" button
* add "Save & Compile & RunLC" button
* add "Send as init.lua" button
* add "Compile & Do LC" button
ESPlorer FileManager
