lethe wrote:Just connect CH_PD (pin 4 on ESP-01) to a GPIO of your Arduino, this way you can completely disable the ESP by pulling the GPIO low.
Thanks a lot !
I have tested your solution and it's what I need
Explore... Chat... Share...
