Is it possible to use an Arduino Uno R3 to firmware update the ESP8266? I have the esp working on my bread board connected to my Arduino via the softwareserial and it works but I wouuld like to load the Lua firmware.
Thanks,
Kris
Explore... Chat... Share...
alonewolfx2 wrote:if you can remove atmega328 on arduino uno, you can use arduino uno's serial chip for firmware upload. arduino uno's tx and rx pins are d0 and d1
