- Thu Mar 26, 2015 1:58 pm
#12684
I've recently started experimenting with the ESP-07 module, I'm currently running NodeMCU with a webserver based on Rui Santos' code found at
http://randomnerdtutorials.com/esp8266-web-server/ . I have 3 LEDs hooked up to 3 GPIO pins through 2.2 Kohm resistors and I've noticed something which may cause problems if I try to do more with it than merely turn LEDs on and off specifically, the LEDs on the GPIO pins glow slightly for about a second or so while the device is powering up. Is this normal? And what's the best way of suppressing it?
P.S. I 'm not entirely sure if I'm posting this in the right place as I'm not sure if it's a hardware problem or a firmware problem
