By picstart
#13033
Code: Select allconst int led = 2;
pinMode(led, OUTPUT);
  digitalWrite(led, 1);
  delay(100);
  digitalWrite(led, 0);
   delay(100);
The above test ( using mycode) is very very very simple and it works
This is a fresh install of Arduino on a win7 64 pro OS. I xxx'd out my folder in users/xxxxx
I downloaded from git hub a zip file arduino-esp8266-master-zip and unzipped it into User/xxxxx/Arduino/hardware
Now when I try the examples in this case hello world there are issues...__dso_handle is missing
Arduino: 1.6.2 (Windows 7), Board: "Generic ESP8266 board"
Build options changed, rebuilding all
HelloServer.cpp.o:(.text.startup+0x8): undefined reference to `__dso_handle'
c:/users/xxxx/documents/arduino/hardware/arduino-esp8266-master/tools/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\Doug\AppData\Local\Temp\build5892183759428858024.tmp/HelloServer.cpp.elf: hidden symbol `__dso_handle' isn't defined
c:/users/xxxx/documents/arduino/hardware/arduino-esp8266-master/tools/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: final link failed: Bad value
Error compiling.
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
By igrr
#13039 Apparently this version of the IDE from @rogerclarkmelbourne was packaged with an older toolchain which had this __dso_handle issue.
As a workaround, you can declare
Code: Select allvoid* __dso_handle;
somewhere in your sketch.
But this should be fixed in the latest toolchain bundled with the version at http://github.com/esp8266/Arduino.
By picstart
#13056
This workaround fixed it.
I am uncertain as to what is the appropriate code to upload
http://github.com/esp8266/Arduino .....This code has a very very different directory structure
The code I thought was current created this structure
user/xxxx/mydocuments/arduino/hardware/arduino-esp8288-master/
esp8266
tools
readme.md
I really don't need more than one working way to use and upgrade this useful IDE will the various options merge?
By Ovaltineo
#13315 Has anyone got WifiClient and WifWebServer examples working? I can compile and upload them but the ESP crashes/locks up during startup.
