This my first post, i have a problem can't communicate RS232 with the esp module. Here i did, Using FTDI232 i connect rx to tx of ESP, and rx of FTDI232 to tx of ESP. I use regulator S1117-33PI which provide 3.3V for ESP. And i connect ground to FTDI,esp and Regulator. CH-PD pin is set by 3.3V.
When power up the ESP, it looks the red LED is turn on and the blueLED blinking in a second. Then, i connect FTDI232 to my laptop. I use hyperterminal and set baud rate 9600, 8bits, no flow,1 stop bits. The i type AT then enter,but no response. But i see the TX LED of FTDI is blinking when press enter but RX led didn't blinking. Then i try all baud rate from 9600 until 115200 but no luck.
So can you help me what's gong on?
Fadli
