but interestingly enough it finds a device under all adresses even with nothing connected to the IO pins
Same with my code.
I recorded the signals with a logic analyser and they don't look like i2c.
Explore... Chat... Share...
Arduino: 1.6.1 (Windows 8.1), Board: "Generic ESP8266 board"
Build options changed, rebuilding all
Using library LiquidCrystal_I2C2004V1 in folder: D:\Users\Michael\Arduino\libraries\LiquidCrystal_I2C2004V1 (legacy)
Using library Wire in folder: D:\ESP8266\tools-utilites\arduino-1.6.1\hardware\esp8266com\esp8266\libraries\Wire
D:\ESP8266\tools-utilites\arduino-1.6.1/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -ID:\ESP8266\tools-utilites\arduino-1.6.1/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -ID:\ESP8266\tools-utilites\arduino-1.6.1\hardware\esp8266com\esp8266\cores\esp8266 -ID:\ESP8266\tools-utilites\arduino-1.6.1\hardware\esp8266com\esp8266\variants\esp01 -ID:\Users\Michael\Arduino\libraries\LiquidCrystal_I2C2004V1 -ID:\ESP8266\tools-utilites\arduino-1.6.1\hardware\esp8266com\esp8266\libraries\Wire C:\Users\Michael\AppData\Local\Temp\build5076188384420751848.tmp\SerialLCD.cpp -o C:\Users\Michael\AppData\Local\Temp\build5076188384420751848.tmp\SerialLCD.cpp.o
SerialLCD.ino: In function 'void setup()':
SerialLCD.ino:19:13: error: no matching function for call to 'LiquidCrystal_I2C::begin()'
SerialLCD.ino:19:13: note: candidate is:
In file included from SerialLCD.ino:1:0:
D:\Users\Michael\Arduino\libraries\LiquidCrystal_I2C2004V1/LiquidCrystal_I2C.h:58:8: note: void LiquidCrystal_I2C::begin(uint8_t, uint8_t, uint8_t)
void begin(uint8_t cols, uint8_t rows, uint8_t charsize = LCD_5x8DOTS );
D:\Users\Michael\Arduino\libraries\LiquidCrystal_I2C2004V1/LiquidCrystal_I2C.h:58:8: note: candidate expects 3 arguments, 0 provided
Error compiling.
