Chat freely about anything...
By pirks
#1123
Code: Select allimport serial
sp="/dev/ttyUSB0"
port = serial.Serial(sp)
while True:
    port.write("AT+RST")
    rcv = port.read(10)
    print rcv
dont work, please help!
By Bert
#1145 What exactly doesn't work?
Also, you are missing a CR+LF (i.e. \r\n) at the end of your command.
By wlinux
#1395 Hey,
The default baud rate for python is 19200, while the default baud rate for the ESP8266 is either 115200 or 57600. Try both of these lines, one of them should work.
Code: Select allport = serial.Serial(sp, 115200)
Or for version one
Code: Select allport = serial.Serial(sp, 57600)
