Chat freely about anything...
By Bomb3rman
#11817 Hi, sorry for the late reply.
This is the code I use:
Code: Select all//Callback for a dns inquire
static void ICACHE_FLASH_ATTR udpserver_recv(void *arg, char *data, unsigned short len) {
    struct espconn *conn=arg;
#ifdef DEBUG
    uart0_sendStr("\r\nDNS INQUIRE\r\n");
#endif
    if (len <13 || data[3] & 0x11110100 != 0) { //valid question
#ifdef DEBUG
        uart0_sendStr("Non standard question\n");
#endif
        return;
    uint16_t numQuestions = ((uint16_t)data[4])<<8 | data[5];
    //build response
    char response[100] = {data[0], data[1],
                          0b10000100 | (0b00000001 & data[2]), //response, authorative answer, not truncated, copy the recursion bit
                          0b00000000, //no recursion available, no errors
                          data[4], data[5], //Question count
                          data[4], data[5], //answer count
                          0x00, 0x00,       //NS record count
                          0x00, 0x00};      //Resource record count
    int idx = 12;
    memcpy(response+12, data+12, len-12); //Copy the rest of the query section
    idx += len-12;
    if (idx > 50) {
#ifdef DEBUG
        uart0_sendStr("Query too long\n");
#endif
        return;
    //Set a pointer to the domain name in the question section
    response[idx] = 0xC0;
    response[idx+1] = 0x0C;
    //Set the type to "Host Address"
    response[idx+2] = 0x00;
    response[idx+3] = 0x01;
    //Set the response class to IN
    response[idx+4] = 0x00;
    response[idx+5] = 0x01;
    //A 32 bit integer specifying TTL in seconds, 0 meas no caching
    response[idx+6] = 0x00;
    response[idx+7] = 0x00;
    response[idx+8] = 0x00;
    response[idx+9] = 0x00;
    //RDATA length
    response[idx+10] = 0x00;
    response[idx+11] = 0x04; //4 byte IP address
    //The ESP's IP address
    response[idx + 12] = 192;
    response[idx + 13] = 168;
    response[idx + 14] = 4;
    response[idx + 15] = 1;
    espconn_sent((struct espconn *)arg, (char*)response, idx+16);
I set up the udp server like this:
Code: Select all    dnsConnUdp.type=ESPCONN_UDP;
    dnsConnUdp.state=ESPCONN_NONE;
    dnsConnUdp.proto.udp = (esp_udp *)os_zalloc(sizeof(esp_udp));
    dnsConnUdp.proto.udp->local_port = 53;
    espconn_regist_recvcb(&dnsConnUdp, udpserver_recv);
    espconn_create(&dnsConnUdp);
Hope it helps.
Works perfectly for me!
By MK1888
#11821 Hi Bomb3rman. Thanks for posting that.
Do we need to include the lwip stuff? SDK0.9.5 seems to have the "++ = 4" code section you posted earlier, so we should just need to define USE_DNS in user_config.h. I tried it, but got no results. Is this something we can change in the nodemcu-firmware project?
