I will keep playing with the hardware, so far I added pull-ups (10k) everywhere possible but this did not help. Tried different power sources - no beef. Different voltages - same.
Good luck
Explore... Chat... Share...
Eyal wrote:Good. I mean good to know I am not alone - bad for you
Good luck
Eyal wrote:I did add caps on the power strip (100n+470u) but I still get the exceptions.
If anyone has any suggestions, or an idea to try, do let me know.
[edit] should mention that replacing the dsleep with restart still fails in the same way.
