https://github.com/chriscook8/esp-arduino-apboot
Looks in EEPROM for SSID and password, trys to connect if it finds one, otherwise it boots as an Access Point with a webserver with which to set a SSID and password into eeprom.
Explore... Chat... Share...
Search SSID: NiceSSID
Search Password: MyPassword
Found SSID at: 0x07E010
Found Password at: 0x07E037
Found SSID at: 0x07E144
Found Password at: 0x07E164
07E010 | 4E 69 63 65 53 53 49 44 00 00 00 00 00 00 00 00 | NiceSSID........ |
07E020 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ |
07E030 | 03 05 03 00 03 00 01 4D 79 50 61 73 73 77 6F 72 | .......MyPasswor |
07E040 | 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | d............... |
07E050 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ |
07E060 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ |
07E070 | 00 00 00 00 00 00 00 00 | ........ |
07E140 | 08 00 00 00 4E 69 63 65 53 53 49 44 00 00 00 00 | ....NiceSSID.... |
07E150 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ |
07E160 | 00 00 00 00 4D 79 50 61 73 73 77 6F 72 64 00 00 | ....MyPassword.. |
07E170 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ |
07E180 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ |
07E190 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................ |
07E1A0 | 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF | ................ |
