I have a problem no connectivity between the lua code MQTT and mosquitto running on ARM cpu such as RaspberryPI and BeagleBoard wit configuration default.
The same code has connection with my mosquitto linux running on Intel defaul setup or iot.eclipse.org.
I've tried everything , ports are open , for example I connect to the ARM Mosquitto from mqtt-spy and from mqtt.js perfectly.
Anyone have any idea why since Lua code MQTT not connected to Mosquitto running on ARM cpu ?
Thank You.
Leo.
