SI7021 works much better than DHT11/DHT22.
power consumption is very low, and much more accurate.
http://www.nodeusb.com
Explore... Chat... Share...
Jan Marius Evang wrote:whats_up_skip wrote:I am surprised that there are no simple temperature and humidity sensors based on the ESP8266 listed.
I have found similar designs, but they also involve an Arduino type device in the circuit.
Example: http://www.instructables.com/id/ESP8266 ... ty-logger/
I thought the ESP8266 along with only a DHT22 temperature and humidity sensor and a few passive components would have been all that is required, or am I missing something here?
I made a temperature logger with a DHT11 + ESP8266(-01) + USB 3.3v power. Very simple with the nodemcu firmware and some pieces of code I found on the net. https://thingspeak.com/channels/29692
DHT22 is more accurate than DHT11.
Marius
