ESP8266 Webserver Project
Moderator: Sprite_tm
By Patriko
#15922 Hi!
When trying to compile it under Windows / Eclipse using attached Makefile I got a loooooonnnggg list of "Entering directory", up to 20 000 repeats causing system hang. What can be the reason?
Thanks!
Code: Select all19:36:01 **** Incremental Build of configuration Default for project ginxm ****
make all
make[1]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[2]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[3]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[4]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[5]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[6]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[7]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[8]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[9]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[10]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[11]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[12]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[13]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[14]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[15]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[16]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[17]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[18]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[19]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[20]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[21]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[22]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[23]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[24]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[25]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[26]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[27]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[28]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[29]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[30]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[31]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[32]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[33]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[34]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[35]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[36]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[37]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[38]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[39]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[40]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[41]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[42]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[43]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[44]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[45]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[46]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[47]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[48]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[49]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[50]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[51]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[52]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[53]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[54]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[55]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[56]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[57]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[58]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[59]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[60]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[61]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[62]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[63]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[64]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[65]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[66]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[67]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make[68]: Entering directory `C:/Espressif/examples/esp-ginx-master'
make: *** [.subdirs] Error 66048
Command canceled
