By danbicks
#16110 Hi Bykubi,
Firstly awesome project, I'm going to build one of these.
How do I configure the lua path to set time to Greenwich mean time UK?
Thanks
Dans
By kubi
#16132 Hi Dans,
thanks a lot.
Just edit the "ntp.lua" file and set the "timezone = 0" ( line 16).
Good luck and have fun,
Kubi.
By danbicks
#16135 Hi Buddy,
I have uploaded all and have the correct nodemcu version as specified.
Oled does not seem to display, I have this board working perfect with native code and also Arduino IDE code.
Looking at your file there is a declaration for -- hardware definitions
sda = 4
scl = 3
I am using a ESP01 this module only has Gpio 0 and 2?
I have tried the obvious when I set these pins to SDA = 0 / SCL = 2 the code moans about can't set D0 on SDA?
Any ideas would be brill.
Thanks mate
Dans
