In such case, you can erase them by flashing "blank.bin" at 0x0007C000 and 0x0007E000 addresses.
martinayotte wrote:Maybe it try to reconnect using previous Wifi configs which isn't compatible across all firmware/SDK.
I made a new test and if I write
#include <WiFiClient.h>
int status = WL_IDLE_STATUS;
WiFiClient client;
void setup()
delay(20);
Serial.println("WIFI configs");
WiFi.mode(WIFI_STA);
void loop()
Serial.println("connecting to wifi");
connectWifi();
connectSocket();
boolean connectWifi() {
int attempts = 0;
while(status != WL_CONNECTED && attempts < 5){
status = WiFi.begin(ssid, pass);
attempts++;
delay(8000);
if(status == WL_CONNECTED) { return true; }
else { return false; }
return true;
boolean connectSocket() {
if(client.connect(server,port)){ return true; }
It won't print into my serial port. But if I remove "WiFiClient client;" from the begining of my scketch, it works OK (If I remove every reference to "client").
Leandro Silva wrote:It won't print into my serial port. But if I remove "WiFiClient client;" from the begining of my scketch, it works OK (If I remove every reference to "client").
I think ESP8266WiFi.h should replace WiFiClient.h when using the ESP8266. I don't think you should use both.
