Then I upload firmware to esp modele ant it not work. When UART set to 75000 I see -
ets Jan 8 2013,rst cause:1, boot mode:(3,0)
ets_main.c
When 115200 - some garbage and no reaction to any input in terminal
ps sorry for my english
thanks
Explore... Chat... Share...
ets_main.c
mcsa wrote:If I use sdk 0.9.1 for compile, before uploading AT exaple firmware(0x00000.bin and 0x40000.bin), do I need upload full firmware 0.9.1(about 520k) or not?
PS I used module esp-03 with 14pin, to start I pull gpio15 to gnd. With full firmware(520k) its work as expected
