by adding
for(l=0;l<0x7C;l+=4)
WRITE_PERI_REG(REG_SPI_BASE(SPI)+l,READ_PERI_REG(REG_SPI_BASE(HSPI)+l));
in the start of spi_init that work
If i found a best solution I post it
Explore... Chat... Share...
