Thanks
Thanks
Explore... Chat... Share...
void SystemInitDoneHandler() {
// do whatever you want to do here
void user_init() {
// do whatever is independent from connection e.g. uart setup etc. here
// and register the callback to run that code when connection is established (if possible and if autoconnect is true)
system_init_done_cb(SystemInitDoneHandler);
