- Sun Oct 19, 2014 11:22 pm
#1779
nogueira wrote:The find function is on the Stream.cpp and Stream.h. Tiny doesn´t have it. Now I´m using IDE 1.5.8 and it´s working
Aaa yeah, I think I've mentioned that at the github readme at some point...
BUT I just replaced that find function, it kinda made everything slower then it needed to.. So now it uses a function that actively waits for the response string, or timeouts if it doesn't find it. It constantly reads the serial buffer for the duration of the defined timeout. Seems to work well, and works with the Tiny core out of the box.
It made it way faster to send the data to the server, about 5 seconds from sleep.
Most of it is still the time it takes to connect to the AP, and that seems to change sometimes... I've seen it connect in 2 seconds, or up to 4; and it's hard to know for sure with the default firmware. So it unnecessarily always waits for 4 seconds to connect.
It will be way easier to use the AT firmware that igrr is developing.
I'm changing my code to use that now.
