I am very new to the esp8266.
Just to try it , I would like to implement a simple sever to switch a LED.
I read a lot on the web and I did try but with no success.
I am able to send AT commands, and using them I was able to get the IP from my router. That is all.
I will appreciate very much if someone could help me starting from:
> what to flash in the 8266 using the flasher ? What config should I use ?
> what should I read on the TE at power on or after RST ?
> What lua code should I load on the Loader ? How to check if OK ?
> what else ?
I saw a lot of documentation but nothing so complete.
Thanks a lot for any help .
regards,
Ambro
