* espNTPdigitalClock.ino
* Created: 5/6/2015 2:17:03 PM
* Author: Nigel with help from lots of others.
#include <WiFiUdp.h>
#include <Time.h>
#include <Wire.h>
#include <Adafruit_LEDBackpack.h>
#include <Adafruit_GFX.h>
#include <Ticker.h>
extern "C" {
#include "user_interface.h"
char ssid[] = "*********"; // your network SSID (name)
char pass[] = "?????????"; // your network password
#define localTimeOffset 0UL // your localtime offset from UCT
#define UPDATESECS 1800UL // update every 30 minutes
time_t update;
bool flag = true;
bool colon = false;
// A UDP instance to let us send and receive packets over UDP
WiFiUDP udp;
Adafruit_7segment disp = Adafruit_7segment();
Ticker showTime;
unsigned int localPort = 2390; // local port to listen for UDP packets
const char* timeServer = "sue.wine"; // my own local time server
const char* timeServer2 = "uk.pool.ntp.org"; // fall back to regional time server
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
void setup()
Wire.begin(4,5); // sda,sdl
delay(10);
disp.begin(0x70); // default display for the LED backpack
notime(); // set the display to 8888 with no colon
Serial.println(ssid);
WiFi.begin(ssid, pass);
WiFi.mode(WIFI_STA);
Serial.println("");
WiFi.disconnect();
showTime.attach(0.333,doDisplay);
setNTPtime();
void loop()
if(now() > update) setNTPtime();
if(flag && (now() % 10UL == 0UL)) printTime("Now ",now());
else flag = true;
delay(900);
void doDisplay()
if (year() > 2014){
disp.print(hourFormat12() * 100 + minute()); // I like to see it as a 12 hour clock
disp.drawColon(colon);
disp.writeDisplay();
void setNTPtime()
colon = false;
time_t epoch = 0UL;
if((epoch = getFromNTP(timeServer)) != 0 || (epoch = getFromNTP(timeServer2)) != 0){ // get from time server
epoch -= 2208988800UL + localTimeOffset;
setTime(epoch += dst(epoch));
update = now() + UPDATESECS; // set next update time if successful
colon = true;
else{
colon = false;
update = now() + 30; // or try again in 30 seconds
WiFi.disconnect();
unsigned long getFromNTP(const char* server)
udp.begin(localPort);
sendNTPpacket(server); // send an NTP packet to a time server
delay(1000); // wait to see if a reply is available
int cb = udp.parsePacket();
if (!cb) {
Serial.println("no packet yet");
return 0UL;
Serial.print("packet received, length=");
Serial.println(cb);
// We've received a packet, read the data from it
udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
//the timestamp starts at byte 40 of the received packet and is four bytes,
// or two words, long. First, extract the two words:
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
// combine the four bytes (two words) into a long integer
// this is NTP time (seconds since Jan 1 1900):
udp.stop();
return (unsigned long) highWord << 16 | lowWord;
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(const char* server)
Serial.print("sending NTP packet to ");
Serial.println(server);
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
udp.beginPacket(server, 123); //NTP requests are to port 123
udp.write(packetBuffer, NTP_PACKET_SIZE);
udp.endPacket();
int dst (time_t t) // calculate if summertime in Europe
tmElements_t te;
te.Year = year(t)-1970;
te.Month =3;
te.Day =1;
te.Hour = 0;
te.Minute = 0;
te.Second = 0;
time_t dstStart,dstEnd, current;
dstStart = makeTime(te);
dstStart = lastSunday(dstStart);
dstStart += 2*SECS_PER_HOUR; //2AM
te.Month=10;
dstEnd = makeTime(te);
dstEnd = lastSunday(dstEnd);
dstEnd += SECS_PER_HOUR; //1AM
if (t>=dstStart && t<dstEnd) return (3600); //Add back in one hours worth of seconds - DST in effect
else return (0); //NonDST
time_t lastSunday(time_t t)
t = nextSunday(t); //Once, first Sunday
if(day(t) < 4) return t += 4 * SECS_PER_WEEK;
else return t += 3 * SECS_PER_WEEK;
void printTime(const char s[],time_t t)
flag =false;
Serial.print(s);
printLeading0(hour(t));
Serial.print(":");
printLeading0(minute(t));
Serial.print(":");
printLeading0(second(t));
Serial.print(" ");
Serial.print(dayStr(weekday(t)));
Serial.print(" ");
Serial.print(day(t));
Serial.print(" ");
Serial.print(monthStr(month(t)));
Serial.print(" ");
Serial.println(year(t));
void printLeading0(int n)
if(n < 10) Serial.print("0");
Serial.print(n);
void notime(void)
disp.drawColon(false);
disp.print(8888);
I hope this helps someone.
Nigel.
