I wonder if someone has tried setting up a local MQTT broker on an ESP8266. If not, would it have enough horsepower to run as a MQTT broker? MQTT brokers are less demanding than web servers, right?
Thanks
Explore... Chat... Share...
Maybe someone more skilled than I can do something with this.
http://knolleary.net/arduino-client-for-mqtt/
