I am working on a fridge temperature controller to control the fermentation temp of home brew beer.
Here is my sketch currently http://pastebin.com/NrT74pkB
theres not much too it, pretty much the basic web example and ive put in my controller webpage.
Using an ESP-01.
If I uncomment line 133 it crashes out on the first iteration of the for loop. If I remove the loop and print out each index manually (1 - 3) it prints out fine.
Output looks like this when crashing.
Connected to ACHome
IP address: 192.168.1.59
MDNS responder started
HTTP server started
1:
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
wdt reset
What I am actually doing is trying to find the index numbers for the temperature and then replace those with the actual temperature form the sensor. By changing the start and end index numbers of the for loop i am able to print out different snippets of code.
I could probably just convert the whole page to a single line and just use a text editor to find the character position but I want to know why this is crashing.
Thanks
