About 1/3rd of the way down for the download.
It looks a bit different their way
Explore... Chat... Share...
wifi.setmode(wifi.STATION)
wifi.sta.config("your-SSID","your-PASSWORD") -- need to wait for a few seconds to connect
print(wifi.sta.getip()) -- issue command to see local IP, may print nil prior to connection
idvariable = "your-ubidots-variableID"
token = "your-ubidots-token"
function postUbidots(level)
connout = nil
connout = net.createConnection(net.TCP, 0)
connout:on("receive", function(connout, payloadout)
if (string.find(payloadout, "201 CREATED") ~= nil) then
print("GOOD POST");
end
end)
connout:on("connection", function(connout, payloadout)
local value = node.readvdd33() / 1000;
local var = '{"value": '..value..'}';
local num = string.len(var);
local postval = "POST /api/v1.6/variables/"..idvariable.."/values HTTP/1.1\n"
.."Content-Type: application/json\n"
.."Content-Length: "..num.."\n"
.."X-Auth-Token: "..token .."\n"
.."Host: things.ubidots.com\n\n"
..var.."\n\n";
connout:send(postval)
end)
connout:on("disconnection", function(connout, payloadout)
connout:close();
collectgarbage();
end)
connout:connect(80,'things.ubidots.com')
end
tmr.alarm(1, 60000, 1, function() postUbidots(0) end) -- post to ubicode every minute
