You say "I managed to upload a blank sketch...Now this module does nothing!!" - what are you expecting to happen, a blank sketch does nothing, right? Try a sketch that does something simple:
Serial.println("Hello");
delay(1000);
Use the Arduino IDE with ESP8266 support that you said you've got (from following the instructions here?).
Hook up the ESP using the Uno for FTDI, and with ESP GPIO-0 connected to GND, GPIO15 connected to GND, CH_PD connected to 3.3V.
Click upload in the IDE and you should see in the IDE console the upload happen and it say it completed successfully.
Open the IDE Serial monitor, set speed to 115200 baud, and you should see the Hello's every second.
If that doesn't work tell us exactly which steps did/didn't work.
