By mcsa
#2031
mobyfab wrote:Did you guys try my toolchain as well?
It's not based on cygwin so it should be easier and a lot faster.
how to use you windows toolchain?
I extract it, add examples dir to it, run make and get the same error
Code: Select allCC driver/uart.c
xtensa-lx106-elf-gcc: error: spawn: No such file or directory
make: *** [build/driver/uart.o] Error 1
By mobyfab
#2039 You obviously need to add the toolchain's bin dir to your path, or update the makefiles to specify it.
Also don't use the original examples Makefiles, they are retarded.
Here the Makefile for the AT example: https://gist.github.com/fpoussin/73e3bf45846bec1e5a08 (You need to put the sdk and toolchain in C:/Espressif, or update the makefile)
You can also try to compile esphttp, it should work fine with the correct path.
esptool will fail if not in your path (you can put it with gcc's bins to fix that)
Let me know how that works.
By mcsa
#2042
Thanks for replay.
What ver of SDK needed? I use SDK 0.9.2. I use makefile, that You provide and now received error
Code: Select allLD build/esp8266_at.out
build/esp8266_at_app.a(at_ipCmd.o): In function `at_tcpserver_discon_cb':
C:\esp8266\esp_iot_sdk_v0.9.2\examples\at/user/at_ipCmd.c:1157: undefined reference to `system_upgrade_start'
C:\esp8266\esp_iot_sdk_v0.9.2\examples\at/user/at_ipCmd.c:1171: undefined reference to `system_upgrade_start'
make: *** [build/esp8266_at.out] Error 1
PS YEESS. Its build with SDK 0.9.1. I will try in harware tomorrow.
update: Working in hardwere
What is esphttp?
