- Wed Jun 17, 2015 1:55 pm
#20725
I inadvertently swapped RX and TX when interfacing with an Arduino (using an LLC). After that it was operating erratically. I could send 3 or so serial packets before it would fail with BUSY or ERROR. I attempted to reflash the firmware with esptool but it failed midway (think it got to 34%). I had the Arduino console open at the time on the ftdi device so not sure if that contributed. Anyway now I simply can not connect to it anymore. Everytime I get the following. Is there anything I can do at this point to save it? Thanks
ceylon:esptool andrew$ ./esptool.py --port /dev/tty.usbserial-A4004Rim write_flash 0x00000 ../esp8266_at/bin/boot_v1.1.bin 0x01000 ../esp8266_at/bin/newest/user1.bin
Connecting...
File "./esptool.py", line 471, in <module>
esp.connect()
File "./esptool.py", line 149, in connect
raise Exception('Failed to connect')
Exception: Failed to connect
