I recently purchased two ESP8266 modules, one version 01 and one version 201. I immediately damaged the 01 by connecting it to an Arduino (Doh! live and learn). The 201 was working fine when I connected it to a 3.3v USB converter. I can load firmware no problem and it was running a script to update a Thingspeak app. As I was modifying the dht11.lua code and uploading it with the LuaLoader 0.87 I decided to speed things up by enabling "Uploads at 921600" on the Settings menu. Ever since then the module does not respond to anything I type when it holds Lua firmware. I tried using a firmware called "ESP8266_AT_V00180902_02_baudrate watchdog added" and was able to communicate with the module with AT commands no problem. I have tried several different Lua firmware releases but still no response from the module. If I set the baud to 74880 I get the usual data dump. I am normally using 9600,8,1,N to communicate.
Has anyone seen this issue? Any thoughts on how to fix it? BTW I reset the module by grounding GPIO0 and RST but no luck.
Thanks
Bruster
