I unplugged the usb.
On which pin the esp have you connect the output teleinfo.
I use an assembly with a sfh620a.
My English is very bad.
We can continue in French?
Explore... Chat... Share...
Serial.begin(1200, SERIAL_7E1)
Serial.begin(1200)
Serial.begin(1200)
uart.setup( 0, 1200, 8, 0, 1, 0 )
print("Init ok !")
uart.on("data", 1, function(d)
print("---------------------")
charin = string.byte(d)
print("Char in: "..charin)
hexvaluein = string.format("0x%08x", string.byte(d))
print("Hex: "..hexvaluein)
charshift = bit.rshift(hexvaluein, 0)
print("Char Shift: "..charshift)
char = string.format("%c", charshift)
print("Char out: "..char)
end, 0)
