I'm looking to implement automated lighting throughout my house. I've got the WiFi bulbs and Hub that will interface to a raspberry pi. My idea is to integrate sensors and the wifi transmitter into my light switches and have them report back to the pi over my home network.
So within each light switch housing I need to fit:
- an ambient light sensor to detect the current lighting in the room (less lighting needed if there is a lot of ambient light already)
- a motion sensor (to detect if anyone is in the room)
- an on off switch (as an override, can just use the normal light switch that is already there, current plan is to bypass the switch with AC current and just use the switch as a digital input on the board)
- a power coverter (to get from the AC circuit in the wall to DC power)
- the wifi communicator
I'm wondering if there is any way to pull this off without having to buy a separate arduino (the pro mini for example). I've looked at the ESP8266 "thing" on sparkfun, but I'm not sure if it can do what I need. Depending on the light sensor and motion sensor I use, I'm trying to figure out if I can wire them straight to a stand alone ESP8266. Since I'll probably have a dozen of these detectors all over my house, any hardware I can trim down will save me some decent cash.
Right now the light sensor I'm leaning toward is just a simple photocell:
http://cdn.sparkfun.com/datasheets/Sensors/LightImaging/SEN-09088.pdf
and for the motion sensor:
http://www.sparkfun.com/datasheets/Sensors/Proximity/SE-10.pdf
I'm just starting out on this so any suggestions if there is a better way to pull this off are welcome.
Thanks!
