http://www.esp8266.com/wiki/doku.php?id=getting-started-with-the-esp8266
You will see that here GPIO2 is left floating
So we have two conflicting references . Will you work with me to sort out why ?
Explore... Chat... Share...
tytower wrote:This guy obviously cant accept that he might be wrong in calling me wrong . Go whichever way you want, but high or floating are definately correct and no-one is wrong . I am fed up with his stupidity-same post four threads
tytower wrote:If I wire up 2 1.5 volt batteries in series I get 5 volts
If I wire up 2 more and put them in parallel you will find that an acceptable 5 volt supply
You will have to add an interupt somewhere . See Arduino.cc interupts.
