By Zemzem Mehdi
#22254 Hello Everyone
I'm new to ESP01 developing and i'm facing a bit of a problem here .
I'm connecting my ESP to the PC through a USB/TTL 3v3 adapter without Reset and DTR but i'm sure i made the correct connections because i managed to get answer from the ESP and to upload my own code using the Arduino IDE.
My Problem is the following :
This Code Works
Code: Select allvoid setup() {
Serial.write("hello");
delay(5000);
But this one shows nothing on the Serial Monitor :
Also i tried the HelloServer Exemple , none of the Serial.write Works but i know that the code is working because i managed to find the webpage and see the message displayed.
Help me please and thank you
By brutzler
#22282 Second code is working too. (on my ESP)
Perhaps you are starting the serial monitor too late?
BTW:
Why is this a "serial.read" problem?
By Zemzem Mehdi
#22324 The Thing is that sometimes i flash a code(mostly when flashing something with Wifi and Serial in it ) and leave bootloading mode(GPIO0 from GND to floating ) , the esp stops being detected by my pc so i can't even check the serial monitor.
for the name thing, i also have a serial read problem. Every time i try Serial.read() , the arduino IDE stops working and i have to kill the program.
   if(Serial.available())
    Serial.write(Serial.read());
