if your handle client call triggers the wdt you won't notice.
I would print ms value before and after the call.
Cal
Explore... Chat... Share...
work time before handleClient[s]= 31.00
work time after handleClient[s]= 31.00
work time before handleClient[s]= 31.01
work time after handleClient[s]= 31.01
work time after handleClient[s]= 31.02
work time before handleClient[s]= 31.02
work time after handleClient[s]= 31.03
work time before handleClient[s]= 31.03
work time before handleClient[s]= 31.04
work time after handleClient[s]= 31.04
work time before handleClient[s]= 31.05
work time after handleClient[s]= 31.05
work time before handleClient[s]= 31.06
work time after handleClient[s]= 31.06
work time after handleClient[s]= 31.07
work time before handleClient[s]= 31.07
work time after handleClient[s]= 31.08
work time before handleClient[s]= 31.08
work time before handleClient[s]= 31.09
work time after handleClient[s]= 31.09
work time before handleClient[s]= 31.10
work time after handleClient[s]= 31.10
work time after handleClient[s]= 31.11
work time before handleClient[s]= 31.11
work time after handleClient[s]= 31.12
work time before handleClient[s]= 31.12
work time before handleClient[s]= 31.13
work time after handleClient[s]= 31.13
work time before handleClient[s]= 31.14
work time after handleClient[s]= 31.14
work time after handleClient[s]= 31.15
work time before handleClient[s]= 31.15
work time after handleClient[s]= 31.16
work time before handleClient[s]= 31.16
work time before handleClient[s]= 31.17
work time after handleClient[s]= 31.17
work time before handleClient[s]= 31.18
work time after handleClient[s]= 31.18
work time before handleClient[s]= 31.19
work time after handleClient[s]= 31.19
work time after handleClient[s]= 31.20
work time before handleClient[s]= 31.20
work time before handleClient[s]= 31.21
work time after handleClient[s]= 31.21
work time before handleClient[s]= 31.22
work time after handleClient[s]= 31.22
work time before handleClient[s]= 31.23
work time after handleClient[s]= 31.23
work time after handleClient[s]= 31.24
work time before handleClient[s]= 31.24
work time after handleClient[s]= 31.25
work time before handleClient[s]= 31.25
work time before handleClient[s]= 31.26
work time after handleClient[s]= 31.26
work time before handleClient[s]= 31.27
work time after handleClient[s]= 31.27
work time after handleClient[s]= 31.28
work time before handleClient[s]= 31.28
work time after handleClient[s]= 31.29
work time before handleClient[s]= 31.29
work time before handleClient[s]= 31.30
work time after handleClient[s]= 31.30
work time before handleClient[s]= 31.31
work time after handleClient[s]= 31.31
work time after handleClient[s]= 31.32
work time before handleClient[s]= 31.32
work time after handleClient[s]= 31.33
work time before handleClient[s]= 31.33
work time before handleClient[s]= 31.34
work time after handleClient[s]= 31.34
work time before handleClient[s]= 31.35
work time after handleClient[s]= 31.35
work time after handleClient[s]= 31.36
work time before handleClient[s]= 31.36
work time after handleClient[s]= 31.37
work time before handleClient[s]= 31.37
work time after handleClient[s]= 31.38
work time before handleClient[s]= 31.38
work time before handleClient[s]= 31.39
work time after handleClient[s]= 31.39
work time before handleClient[s]= 31.40
work time after handleClient[s]= 31.40
work time after handleClient[s]= 31.41
work time before handleClient[s]= 31.41
work time after handleClient[s]= 31.42
work time before handleClient[s]= 31.42
work time afte
ets Jan 8 2013,rst cause:4, boot mode:(3,7)
wdt reset
load 0x40100000, len 28780, room 16
tail 12
chksum 0xef
ho 0 tail 12 room 4
load 0x3ffe8000, len 1548, room 12
tail 0
chksum 0x90
load 0x3ffe8610, len 3080, room 8
tail 0
chksum 0x22
csum 0x22
r?
Connected to @HomeCA72
IP address: 192.168.1.102
MDNS responder started
HTTP server started
void loop(void){
unsigned int ms=millis();
float sec=float (ms)/1000;
if (sec>31)
Serial.print("work time before handleClient[s]= ");
Serial.println(sec);
server.handleClient();
ms=millis();
if (sec>31)
Serial.print("work time after handleClient[s]= ");
// digitalWrite(led, 1);
// delay(1);
// digitalWrite(led, 0);
// delay(1);
work time [s]= 1226.49
work time [s]= 1226.59
work time [s]= 1226.69
work time [s]= 1226.80
work time [s]= 1226.90
work time [s]= 1226.99
work time [s]= 1227.09
work time [s]= 1227.19
work time [s]= 1227.30
work time [s]= 1227.40
work time [s]= 1227.50
work time [s]= 1227.60
work time [s]= 1227.70
work time [s]= 1227.80
work time [s]= 1227.90
work time [s]= 1228.00
work time [s]= 1228.10
