it only happens when it's connected to my Fritz.box 7270 router.
when I connect to another router it works just fine (with some delays actually)
as workaround for the fritz I periodically send ARP broadcast
extern struct netif *netif_list;
struct netif *netif = netif_list;
while (netif)
struct pbuf *q = pbuf_alloc(PBUF_RAW, 60, PBUF_RAM);
if (q != NULL) {
struct eth_hdr *ethhdr = (struct eth_hdr *)q->payload;
struct etharp_hdr *hdr = (struct etharp_hdr *)((u8_t*)ethhdr + SIZEOF_ETH_HDR);
os_memcpy(ðhdr->src, netif->hwaddr, 6);
os_memset(ðhdr->dest, 0xff, 6);//broadcast
os_memcpy(&hdr->shwaddr, netif->hwaddr, 6);
os_memset(&hdr->dhwaddr, 0, 6);
IPADDR2_COPY(&hdr->sipaddr, &netif->ip_addr);
IPADDR2_COPY(&hdr->dipaddr, &netif->ip_addr);
hdr->hwtype = PP_HTONS(1); //HWTYPE_ETHERNET
hdr->proto = PP_HTONS(ETHTYPE_IP);
/* set hwlen and protolen */
hdr->hwlen = ETHARP_HWADDR_LEN;
hdr->protolen = sizeof(ip_addr_t);
hdr->opcode = htons(1);
ethhdr->type = PP_HTONS(ETHTYPE_ARP);
else {
LWIP_ASSERT("q != NULL", q != NULL);
netif->linkoutput(netif, q);
pbuf_free(q);
netif = netif->next;
I'm using old DLINK DIR-300.
I tried to connect directly to module.
Ping time is just 5ms!
It's much better.
I am playing with http server on host MCU.
It works very strange, I have a lot of troubles when module connected to router.
When I am connected directly to module I have not troubles.
kingfisher, are you able to release firmware to upgrade modules?
111 12:08:40.246544 Avm_xxxxxxx Espressi_98:72:c9 EAPOL 179 Key (Group Message 1 of 2)
114 12:08:40.252149 Espressi_98:72:c9 Avm_xxxxx EAPOL 131 Key (Group Message 2 of 2)
just to say...
I cannot find any workaround for that.
one good point could be to use wifi_set_promiscuous_rx_cb and wifi_promiscuous_enable and reset the connection as soon as such a packet is received
but it looks like they work only if set in user_init() and if set they prevent from connecting to the AP.
