I am interested in changing this to my own name just for kicks. Does anyone know the address to do this?
Explore... Chat... Share...
struct softap_config {
uint8 ssid[32];
uint8 password[64];
uint8 ssid_len; // Note: Recommend to set it according to your ssid
uint8 channel; // Note: support 1 ~ 13
AUTH_MODE authmode; // Note: Don't support AUTH_WEP in softAP mode.
uint8 ssid_hidden; // Note: default 0
uint8 max_connection; // Note: default 4, max 4
uint16 beacon_interval; // Note: support 100 ~ 60000 ms, default 100
bool wifi_softap_get_config(struct softap_config *config);
bool wifi_softap_get_config_default(struct softap_config *config);
bool wifi_softap_set_config(struct softap_config *config);
bool wifi_softap_set_config_current(struct softap_config *config);
